Steel Wheel Code ID
Steel Wheel Code ID
Anyone know where I can find the codes for steel wheels?
I have these steeleys & don't know what they are for:
1. GM 5 bolt hole 15x6 "RF"
2. gm 5 bolt hole 14X6 "29 A"
Thanks in advance
Derek
Thanks in advance
Derek
RF code: http://www.ebay.com/itm/NOS-75-Olds-...890a6e&vxp=mtr
Is it possible the other one is just an "A" code wheel? This is from a post I found here:
...I was thinking that some of the 65-66 olds vista wagons came with the 14x6 rim with a 1.00 offset As well as some of the f85 with HD suspension. I know I pulled a set of rims off a 67 vista cruiser with a code of 6 A3 that were 14x6JK, with a 1.00 offset, dated 67; but I don't know if they were original.
I was also told that at some time the J-88 also used a 14x6 rim with code A.
I currently have 3 of rims in the garage, code A., 14x6 JK (6" is bead to bead), 1.00 offset, center section stamped gm 64 or gm 65 (Not sure which).
I have also read that some of the Pontiac's, gto for example used the same rim, although the stamped code could be different. Just read last night from a Pontiac restoration guide that they used gm 3871919 for the 64-67 got; but you know there are lots of errors out there on the internet.
Derek, are you sure the code is 29 A, is there something to the right of the valve stem? Any stampings on the tire side of the rim?
