Starter?
Old May 30, 2020 | 06:57 PM
PM70's Avatar
Starter?
Its taking longer to start and thers a puff of smoke coming from under the hood, drivers side, at the front. Starter? If so, how hard is to change out w/ a new one? Thanks.
Old May 30, 2020 | 07:21 PM
Tedd Thompson's Avatar
No starter resides at the driver side front. What kind of smoke, electrical oil blowby? Have someone watch as you start the car. not enough info to venture a guess..... Tedd
Old May 30, 2020 | 07:32 PM
PM70's Avatar
White puff. And then it's gone. Def not oil. Drivers side, towards the front of the car. Happens just at turn of the key, before the engine turns over. Starter cranks and cranks mostly when it's cold, starts better when warm, but not always. I thought I heard it slip the other day but can't be sure
Old May 30, 2020 | 07:40 PM
Sugar Bear's Avatar
Year, model, engine...
Insulation from an overheated wire from excessive current. Check the small ground wire to the body. If it's melting the large ground is bad.
Old May 31, 2020 | 08:30 AM
PM70's Avatar
Turned out to be the small ground to the battery. It has split - I have it temporarily hooked back up and the car fires right up, but the insulations totally gone, so I'll get it replaced. Once again, thanks for the excellent info on this site
Old May 31, 2020 | 08:56 AM
Sugar Bear's Avatar
There is a problem with the engine ground wire, the heavy cable between the battery and the cylinder head. The small wire should not be carrying cranking loads; it did because the heavy wire has high resistance and the load took next path of least resistance, in this case the little ground wire from the battery.
If only the little wire is replaced it will fail again and the car will have unexplained electrical gremlins.
Good luck!!!
Old May 31, 2020 | 04:40 PM
PM70's Avatar
Good luck!!!
Ok great info. Thanks again!
stellar
Sep 22, 2018 06:43 AM
70cutty
Aug 18, 2013 05:28 PM
timothypaul
Aug 2, 2013 07:40 AM
88hurstolds
Jan 11, 2013 07:43 AM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
