Six weeks of work
Old Aug 22, 2024 | 08:32 PM
34487's Avatar
Six weeks of work
I went to take the Olds for a drive and found that the two front core plugs were leaking. I replaced core plugs,water pump, fan clutch,intake gaskets,thermostat and added the H.D cooling pulley set up. now I have a car that will idle in traffic without getting hot.Thanks to this forum I found that I had the wrong length water pump(5.6) on it and the H.D.pulleys I had wouldn't lineup, now with the correct parts I now have the best cooling Olds I've ever owned!. I also changed out the Holley spread bore for a Qjet and removed the 3.42 rear gearset and replaced it with a 2.73, This works good for me as I live in a rural area (one stoplight in the county)and now I can drive further with the engine in it's sweet spot. I would like to thank the forum for all the info so I could add all the correct parts.!
Marc
Old Aug 22, 2024 | 09:41 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Thanks for acknowledging the folks here that helped you on your car. As I have said many times, there are lots of people here with lots of knowledge who are glad to help. I am glad you are enjoying your car now.
Old Aug 23, 2024 | 04:26 AM
Excellent!!
therobski
Sep 28, 2020 04:15 PM
scrappie
Jan 30, 2018 03:06 PM
toymobile
Oct 28, 2017 09:30 AM
kad36
Dec 9, 2016 07:14 AM
RROLDSX
Apr 15, 2016 05:50 AM
