Shifter problem
Old Jun 13, 2018 | 06:56 AM
melo123's Avatar
Shifter problem
I purchased a tribute 71 olds 442 with the Hurst slapstick shifter.
The shifter doesn't always allowed the car to be started in park have to move it to neutral position. Also the shifter has to be pulled passed the drive position to get it to go into drive then pushed back into the drive slot. Is there a different length cable for the hurst shifter then the original cable that was on the Olds Cutlass Supreme that the car was originally?
I have adjusted the cable underneath as far forward as possible to try and eliminate the park issue. this then caused the issue with the drive position.
Any advice good or bad will be appreciated.
Old Jun 13, 2018 | 07:07 AM
Adjust the cable so all the gears shift correctly. Then adjust the neutral safety switch so it starts in both park and neutral.
Old Jun 13, 2018 | 07:11 AM
melo123's Avatar
Thanks... will need some help with the actual adjusting of the cable.
Old Jun 13, 2018 | 07:21 AM
I've found that wives or girl friends are really good for supplying a 3rd hand.
Old Jun 13, 2018 | 09:20 AM
Can you clarify what shifter that is?
Old Jun 13, 2018 | 11:10 AM
melo123's Avatar
The shifter is a Hurst Slapstick also as I am told referred as his and hers shifter.
Old Jun 13, 2018 | 12:16 PM
Is it the stock his and hers, is what he is asking.
Old Jun 13, 2018 | 01:50 PM
That would be a Hurst Dual Gate shifter.
It can be a bit tricky to get the shifter adjusted perfectly. It took me many tires to get mine adjusted so Park and 1st would both engage properly. Put the shifter in 1st, adjust the linkage on the side of the transmission (loosen the nut/bolt), move the shifter ear so you can feel the pawl engage in the low gear notch, tighten the nut/bolt, then move the shifter to Park and check if you can remove the key. If not, loosen the nut/bolt and move the shifter ear a little bit, tighten, and try again. Keep repeating until you get both ends of the span adjusted correctly.
Note: If your shifter has a lot of slop, or if the backdrive linkage is loose, it may not be possible to get it adjusted correctly.
86Salon
May 24, 2016 05:45 PM
becerra66
Apr 29, 2015 04:01 AM
nitrovette
Aug 12, 2014 04:15 PM
onofre442
Jan 24, 2013 11:08 AM
bcade
Nov 27, 2011 08:09 AM
