Shifter bracket
Old Apr 21, 2022 | 01:52 PM
tkcutlass's Avatar
Shifter bracket
Trying to put together everything I need for my dual gate install.
I have a floor shifter bracket from a Th350 and it doesn't seem to fit the Th400
I could probably force it on but it will never fit over the shoulder. of the bolt.
Maybe it's a different size based on the transmission year? (need to double-check the year on the th400)
Old Apr 21, 2022 | 06:45 PM
The bolt pattern on the TH400 pan is different and so is the bracket.
Old Apr 21, 2022 | 09:03 PM
tkcutlass's Avatar
I am hoping this one will do the job.
Pn# - INL10765
1969-79 GM A-body Pontiac - GTO, Judge, Lemans, Tempest, Grand Prix, 69-77 trans Am Automatic trans t-400 floor shifter cable bracket for center console cars. 1pc.
This is the bracket that mounts to the trans on center console cars. It is used to shift the transmission. If you are adding a console or floor shifter to your car this bracket is a must to get the cable to work. This is an inline tube exact reproduction of the original with silver zinc plating.
Applications:
1969-79 Chevelle, GTO, 442, GS, Elcamino
1970-79 Monte Carlo, 1969-72 Grand Prix
1969 Camaro, Firebird, 69-74 Nova
1970-79 Firebird / Trans Am / Camaro
1973-79 A-body Chevelle, Lemans, Cutlass, Skylark
all Full Size Cars from 69-78
Any GM Car with the T-400 Transmission
Old Apr 22, 2022 | 02:53 PM
69442murph's Avatar
I think this is what you should be looking for the turbo 400 floor shift. Thanks
Old Apr 22, 2022 | 03:02 PM
The bracket that bolts to the PAN is the one that is different. The shift arm bracket fits both transmissions. Be sure there isn't a burr on the end of the shaft.
Old Apr 22, 2022 | 08:42 PM
tkcutlass's Avatar
Joe thanks for verifying the shift arm fits both.
Took a little persuading but I was able to wiggle it on.
Mar 23, 2023 10:47 AM
BeenThere
Feb 15, 2021 07:20 AM
hotrod
Aug 12, 2013 01:06 AM
ziff396
Sep 22, 2009 08:06 AM
Jamesbo
Hurst/Olds
Jan 20, 2009 03:31 AM
