Questions about tissue dispenser 🤔
https://classicoldsmobile.com/forums...penser-147732/
You squeeze the sides in and those metal tabs retract enough for the top to come off. It has a molded boss with 3 holes that I think you just screw to lower dash. It's supposed to be opening down, as seen by the rocket emblem orientation.
I think it doesn't get one, bud. Flip it over and see if there's a flat spot with three holes. Yes, I think it could be considered correct for a 72 Supreme. There was the tissue box, then the trash box, then the combined one of both; so, at least 3 types.
Would that be part #983191 or 983009?
https://www.ebay.com/itm/NOS-Tissue-...-/254850234988
It mounts wherever you want to put it. This wasn't something that was factory engineered with detailed installation drawings. It's an aftermarket add-on that the dealer network sold. It just screws to the metal bottom of the dash. If you put it right under the glovebox, it will probably be a knee-knocker for the passenger.
These definitely came with a bracket, The piece with 3 holes is the bracket. The dispenser slid in and out of the bracket to service it. Nobody sells the bracket, and it would be difficult to make a nice one.
