PSA Check your ground straps
Old Apr 3, 2021 | 05:11 PM
curvewrecker's Avatar
Long story short I had a temp gauge that was flickering badly for a while now. I finally noticed a lack of a ground strap between the engine and chassis. Once I added that things all went back to normal.
Check your straps if you've got electrical gremlins!
Old Apr 3, 2021 | 07:38 PM
Owen Miller's Avatar
Ground straps
I would like to add to this. If ground straps are not hooked
up and with a good connection, if you have floor shift, the
engine will find a ground through the shift cable. Cables are
not cheap.....
Old Apr 3, 2021 | 08:41 PM
VI Cutty's Avatar
The current will find the easiest path to ground. I was cranking the engine in a parts car and didn't realize the engine's ground strap wasn't well grounded. The metal line for the oil pressure gauge turned into the ground and was really heating up!
Old Apr 4, 2021 | 05:04 AM
fleming442's Avatar
You can never have enough grounds!
battery to block, battery to body, block to frame, block to body, frame to body... as big as you can get! Braids work well, too.
I know some of that won't fly with the restonerds, but remember: DC electrons actually flow negative to positive.
yyyktk1
Apr 15, 2020 06:06 AM
bcg88
Nov 15, 2013 07:38 PM
ChefDeadpool
Dec 26, 2010 07:55 AM
silverriff
Mar 12, 2010 04:22 PM
projectheaven
Jan 1, 2009 09:58 AM
