On point with points
Guest
Posts: n/a
Pardon my ignorance gents; however, I'm not too familiar with points. My '72 cutlass, how many points do I have so that I can replace them? I wanted to conclude a tune-up to ensure she fires up right away every time. Thanks for the help fellas.
I have heard of a dual point system (old school hot rodding stuff way b4 my time) I have never seen one. I would guess that you are going to be running a stock system if you are asking this w/o mentioning a brand dist. You will be looking for one set of points and condenser. I have messed with them a bit, but not much and not for some time. Others will have to chime in for tuning tips.
You probably have a stock distributor which will contain one set of points and one condenser. They were originally separate but you may have what is referred to as a uniset where they are made into one unit. This may be the only way they come anymore. The uniset is easier to install. The points are adjusted externally with an allen wrench through the window on the distributor cap. You will need a dwell meter and set them at 30 degrees. Be sure and disconnect the vacuum hose from the distributor before you set the dwell. I am going out on a limb here and say you can set them at 16 thousands with a feeler gauge if you do not have a dwell meter. I am going off my memory on that one and it has been several decades since I have done that.
I have seen it done, but am not sure exactly what is necessary. I THINK a ballast resistor is removed from the hot to the p/c system, and attached to the hot lead for the HEI, but would need to do some digging to confirm. Not sure if anything else is needed.
Looking at this after the fact I was not clear. The resistor i believe is removed from the car in this conversion.
csstrux, you are correct on the hookup for the HEI. It needs a full 12 volts to it which is switched with the ignition. If you have it, I would use it. It will be a huge improvement and start a lot quicker. You will need a new set of plug wires and may want to widen the gap on the plugs a little. Interesting comment on the matchbook cover. Never used that trick. Problem is finding a matchbook these days.
i will be trying the Pertronix soon. i am taking out my HEI to put the original air breather base back in my car. depending on what car you have you may run into a clearance issue with your HEI
If you have a dwell gauge you can set the points to 30 degrees or you can use a feeler gauge and set it at .016 and that should be dead on. Putting Pertronix in would be easier than going with the HEI distributor. Also, the HEI distributor does not get the same centrifigal advance as a points type distributor due to the non-performance springs and weights on the top of the distributor. (They came that way so emissions would be better) You may notice a drop in power because of this. Hope that helps.
I always wondered why my buddy 327 ran better when we had points in it. We put in an HEI and never got it to run the same.
Josh
If you still use the points and condenser don't forget a little point lube for the cam block. (if they still sell it) The Pertronix is neat cause you maintain the stock look, but gain the advantages of an electronic set up.
Pertronix makes good stuff. I just put them in my friends 50, 54 and 68 Oldsmobiles. I put one in my boat about 10 years ago. I have had a HEI in my 72 Cutlass for 15 years and it has worked perfect. If I was buying one today, I would use Pertronix. If I had an HEI, I would use it. On second thought, I would probably use the Pertronix since you don't have to screw with air cleaner clearance and the point distributor is smaller in diameter and you would not have to buy new wires.
The Factory Service Manual is a very handy tool to have.
WIn the meantime, you can download this PDF file . Start at page 31.
Point gap is .016" (I use .018")
Dwell angle is 30° (I use 28°)
Or you can turn the adjusting screw in, until the engine misfires, then turn it out ½ turn.
Most important, is to make sure the cam is lubricated properly.
Norm
Norm
One set closed the circuit and the other opened it. Half the wear and more dwell.
I used one in my 288 inch Chev. 7K without missing a beat.
And the emery board can be used as a point file.
Norm
Norm
. As previously stated I don't think I have ever seen one
Not as popular as they were before electronics took over, but Mallory still makes them.
This one is an Accel Conversion kit for GM point distributors.
Norm
Last edited by 88 coupe; Apr 27, 2009 at 04:33 AM. Reason: Corrected the Year One link. (twice)
No. The staggered setup allowed for more dwell, which gave the Coil more time to saturate. Longer saturation = hotter spark at higher RPM. Half (theoretically) the rubbing block wear, was icing on the cake.
Norm
Norm
Thanks Norm
