Oil Pump Pickup
Old Nov 28, 2016 | 08:07 AM
Cpriester123's Avatar
Oil Pump Pickup
Quick question, has anyone ever pressed in a brand new pick up screen into a pump. Then remove that screen and installed it onto another pump that also once had a screen in it before as well?? My reason for asking is because I'm curious to know if this would hold up and not damage anything and fitment remain sufficient....
P.S.
I damaged my pump while installing and do not trust to use the pump so I want to use the same screen on another identical pump that I have an extra of.
Old Nov 28, 2016 | 08:52 AM
ELY442's Avatar
No not me but after the horror stories I hear about the "pressed on" type, I went out buying the "bolt on" type. Do yourself a favor and have a few tack welds on the "pressed on" type onto the pump to be on the safe side.
Old Nov 28, 2016 | 09:39 AM
X2 on tack welding, it does not happen very often but they do fall off.
Old Nov 28, 2016 | 11:33 AM
Well I have a standard pump by melling and the only fitment for a standard volume pump is the press on. The high volumes have a bolt in but I was recommended to not use the high volume because I was told a high volume is recommended for bigger horses.
Old Nov 29, 2016 | 04:50 AM
toymobile's Avatar
Back in 1972 I lost a fresh built 425 because the pick up came out, Thought with the pump in the bottom of the pan it would work EVEN WITHOUT pick, Get a NEW PICK UP good insurance.
Johnny
csouth
Aug 26, 2012 06:16 PM
RAMBOW
Feb 25, 2012 11:31 AM
88hurstolds
Oct 6, 2011 08:26 PM
1FSTLS1
Jan 16, 2011 02:32 PM
cts-v
May 26, 2009 06:52 PM
