oil length of time to keep brake
Old Apr 1, 2025 | 05:27 AM
Jaybav's Avatar
Which oil is best for a Olds 98 in warm climate
Which weight should one use and which advice on length of time to keep break in oil in the crankcase?
Old Apr 1, 2025 | 07:02 AM
Run to Rund's Avatar
Depending on bearing clearances, probably 10-40 weight oil. If you broke it in with moly camshaft lube on some parts, it should have been changed after the 20-30 minute cam break in.
Old Apr 1, 2025 | 05:46 PM
If you are asking about break-in oil, straight SAE 30 is typically used. I'd be more worried about using a high quality break-in oil for flat tappet cams. I usually change after cam break-in then again at about 500 miles.
griffey57
Dec 31, 2023 04:49 PM
otto72
Sep 1, 2020 08:53 PM
scooter123
Mar 5, 2014 11:23 AM
Tedd Thompson
Jun 14, 2012 07:28 PM
