Offset balanced flywheel?
Old Nov 5, 2015 | 07:18 PM
Charlie Jones's Avatar
Phantom Phixer
This guy says 55-57 , I don't think he really has a clue.
55-56 would be neutral balanced , 57 would be offset.
Lots of holes drilled on one side. Maybe offset ? Maybe just poorly balanced wheel ?
http://www.ebay.com/itm/Oldsmobile-C...dWO4GY&vxp=mtr
Old Nov 7, 2015 | 12:33 PM
Tedd Thompson's Avatar
I would not think it to be NOS with it being aluminum. Probably aftermarket. Weren't 57-58 balanced with add on weights rather than drilled or Am I thinking flex plates here?... Tedd
Old Nov 8, 2015 | 09:20 PM
Ozzie's Avatar
The factory synchromesh flywheel part numbers were:
564281 for 1954-56
568944 for 1957-59
So, they were different, but I don't remember what the difference was.
Old Nov 9, 2015 | 12:08 PM
I haven't seen many stick type flywheels for those year Old's( most are automatics) but all I can remember were steel....Tedd
Old Nov 9, 2015 | 02:28 PM
Ozzie's Avatar
Yes, the shop manual says that it was of cast iron with a hardened steel ring gear shrunk on to its outside diameter, so the aluminum one would be an aftermarket. It also said that the synchromesh flywheel used longer mounting bolts than the one for the Hydra-Matic.
Sep 23, 2012 08:25 AM
Aceshigh
Jan 16, 2011 10:52 PM
jeffrey
Nov 17, 2010 05:44 PM
Ranzan
Wheels and Tires
Jul 30, 2010 07:48 AM
1973olds98
Wheels and Tires
Jan 31, 2010 10:22 AM
