oai flapper
Old Nov 24, 2011 | 03:49 PM
spasco442's Avatar
oai flapper
Just asking...every pic I see of a oai flapper door the flapper is are always open without vacume to it.When installed just how does it work?
Old Nov 24, 2011 | 04:15 PM
Rickman48's Avatar
Vacuum closes the door at high vacuum, and the motor pulls warm air when the door is closed.
When vacuum drops, the door opens and the carb gets outside air - hence 'outside air induction'.
Old Nov 24, 2011 | 04:54 PM
rocketraider's Avatar
Oldsdruid
To expand on Rickman's simple explanation:
Engine shut off, there is no vacuum. With no vacuum, flapper defaults OPEN.
Start engine, there's vacuum. Flapper closes and stays closed under normal cruise conditions where vacuum is high.
Floor the throttle, vacuum drops off and flapper opens, allowing cold (well, ambient temp, still cooler than underhood air) outside air into the aircleaner.
jozw30
Jul 25, 2015 09:00 PM
1carsick
Jan 16, 2013 04:27 AM
jensenracing77
Sep 30, 2012 03:31 PM
OLDSmobility
Oct 8, 2010 05:54 AM
442oldslawyer
May 16, 2010 07:15 PM
