Is this normal ???
Old Aug 7, 2018 | 11:00 AM
Zr1bandit's Avatar
Is this normal ???
1970 442 with rally pack gauges. My speedometer needle is way below the zero MPH mark when at a standstill, this cant be right ???? When driving it is approx. 5 MPH too slow. If it started out at zero MPH then I think it would be much more accurate. Any ideas ??? How too fix ??? Thanks----Greg
Old Aug 7, 2018 | 11:18 AM
svnt442's Avatar
No, it should sit on 0 when stopped.
Old Aug 7, 2018 | 11:22 AM
Zr1bandit's Avatar
Any idea how to fix ???
Old Aug 9, 2018 | 04:14 AM
Zr1bandit's Avatar
Anybody ave an idea on how to if this ?????
Old Aug 9, 2018 | 05:07 AM
442Fred's Avatar
PM sent
Old Aug 9, 2018 | 09:51 AM
Greg, did you just have this speedo overhauled? The mileage looks like it was. If so it should be under some form of warranty.
Old Aug 9, 2018 | 12:34 PM
RandyS's Avatar
I'm thinking the needle just pushes on to a very thin shaft coming out of the speedo mechanism. You may be able to remove and reinstall it.
Old Aug 9, 2018 | 04:33 PM
m371961's Avatar
Maybe it was pegged past 120 and the needle moved on the shaft!
Old Aug 9, 2018 | 04:52 PM
marxjunk's Avatar
i think you can just pull it off and stick it on where it belongs,,,
Old Aug 9, 2018 | 08:15 PM
Zr1bandit's Avatar
Got it figured out. Pulled off and replaced in proper spot. Thanks
Old Aug 10, 2018 | 10:30 AM
It was that easy?? Who did the restoration on the speedo for you?
Old Aug 10, 2018 | 12:46 PM
oldspackrat's Avatar
I have restored a bunch of these but I don't know/remember if I did this one. If so I would not have shipped it with the needle in the wrong spot. That being said, they are pretty easy to remove & reinstall. Just gently twist the round part of the needle counter clock wise & it will come off then push back onto the stem in the correct position.
Old Aug 10, 2018 | 08:06 PM
Zr1bandit's Avatar
I restored my own gauges, was able to simply pull needle off stem and re-install in proper position-----------thanks for al the help here ---------Greg
tva442
May 27, 2019 06:06 PM
Chris K
Jan 29, 2019 08:25 PM
brandon reynolds
Mar 30, 2018 02:02 PM
Alb
Feb 24, 2010 08:10 AM
