Looking for some advice
Hello all...I'm going to look at some parts cars this weekend and need a little bit of help. My car is a 66 Cutlass and the cars I am going to look at are a 64 and 67. They are both 330's with the Jetaway and I am assuming that these are the same as mine. What I am interested in with these two is what interior parts interchange with mine?(dash,body panels etc) And with the 67...I know the front front grill is a little different but would this swap into mine? It also has power windows which mine does not...are the regulators the same fit? It is not a 442.
Thanks in advance for the help.
67 -dash is basically the same. Front grill won't fit. power windows will work. 330 is the same. The complete interior will fit but the patterns are different.
The 64 has hardly anything in common with the 66
To expand a little, the 66-67 cars are very similar and share a lot of parts. The interior parts are the same, but the upholstery patterns are different. The front fenders, doors, and trunklid interchange. The hood, grill, bumpers, and core support do not (unless you swap the entire 67 nose onto the 66). The 67 frame is slightly different in that it is drilled to accommodate a TH400 that was first available that year. The 330 and Jetaway are virtually identical between the two years.
