Ignition Coil Resistor Wire?
I've read some threads that refer to this...
I'm wondering if my 67 Delta 88 has this resistor wire... and if it is necessary to run a new wire to use an aftermarket (Pertronix or MSD) ignition coil. My coil is working, but looks pretty rough inside (corroded). If my car has the "resistor wire", I may just replace it with a stock coil. Any insight out there?
Yes, if nobody has messed with it.
Pertronix says it's not necessary, but others have found that sometimes it is.
If your coil is working, why mess with it?
If it ain't broke, don't fix it.
From what I gather in the other threads, it's probably best to just run a new separate wire, so the resistor wire stays intact as a backup. I'm not sure if an aftermarket coil would give me any performance gain at all... to justify the added effort?
The car runs really good now. The coil looks pretty old... and it has green corrosion it it. I was going to clean it up, but then thought that might kill it. Maybe just a new OE type coil... which I assume, would use the existing wires?
I agree... but it looks pretty rough. It obviously one of he oldest parts under the hood. If nothin' else I'd like to have a spare in the trunk. If I go with a new aftermarket coil, I'll keep this one as a spare (which is why I want to retain the resistor wire)
You can just cap and stow the resistor wire and run a new wire. On the coil, if it's green because it's leaking and slimy, then another is a good idea. If it's just ugly, a light sanding and some black paint will freshen it right up.
Don't fixate.
Brass corrodes to green. Believe me, it won't slow down 30,000 volts.
It is never a good idea to replace a well-made, fully-functional, American-produced part with a new, poorly-made, foreign part.
bill
I used a universal relay to route power from the junction block on the fender to the ignition. You use the old resistance wire as the trip wire to turn the relay on and off. It works perfect and you don't have to tap your ignition into some other circuit that may be over taxed to begin with.
