Highest compression with 91 octane?
Old Jan 26, 2017 | 10:16 AM
Mikey_mick's Avatar
So here's the deal. I'm about to rebuild my 455 olds and I'm wondering what compression ratio I should shoot for. In my part of NW Iowa, it's hard to find anything higher than 91 octane (unless I wanted to convert to e85). I was thinking that I would be safe at 9.5-1 CR but then a guy at work said that he runs 91 oct in his 10-1 cr Pontiac 455.
So what do you guys think? Could I go 10-1?
Old Jan 26, 2017 | 12:26 PM
oddball's Avatar
There's no hard and fast rule. Depends on the head material, piston/head chamber shape, plug heat range, cam profile, timing curve, altitude, rear end gears/tire, etc etc.
In general, aluminum heads seem to do fine around 10:1, sometimes higher, sometimes lower. Iron tends to do fine around 9:1, sometimes higher, sometimes lower.
IMO, it's not worth sweating over a specific compression ratio unless you have some very specific goals. And if it ends up pinging, then back off the timing and/or keep a few jugs of race gas handy to mix in.
Old Jan 26, 2017 | 01:12 PM
I agree with the above.
From what I have learned, the cam intake closing events can make a huge difference in cylinder pressure (dynamic compression ratio) and can make two engines with the same static compression ratio function very differently. So you could get away with 10:1 but you would need the right camshaft profile (and overall tuning).
bluecab
Feb 22, 2012 02:45 PM
greenslade
Mar 29, 2011 03:56 PM
442much
Site Suggestions
Jan 24, 2009 09:15 AM
labrats804
Jul 5, 2007 07:55 AM
