High compression
Old Dec 7, 2011 | 03:50 PM
friskyjake's Avatar
High compression
A friend [way up north has no internet] has a 65 cutlass conv with 52,000 miles on it & is wondering is there a way of lowering the c/r of the 330ci engine, without putting in pistons in it? Is there thicker head gaskets? High octane gas is not available in his area [expect aviation fuel] Thank you
Old Dec 7, 2011 | 03:53 PM
coppercutlass's Avatar
Chevy budget Olds powered
Thicker gaskets are the easiest way i know of most replacement head gaskets are .040 o.e is usually .017-.022 you can also buy thicker ones from corteco they are expensive but reuseable from what i have been told.
Old Dec 7, 2011 | 07:42 PM
DeltaPace77's Avatar
I'd be a bit careful of the amount you raise the heads from the block, as can cause intake manifold fitment/alignment issues. Mixing in a few gallons of 100+ octane racing fuel would be easiest if availible. Not sure of AV gas, as think the octane's rated differently. I used bolt on alcohol/water injection years ago, but not sure the availibility/cost of these now.
Old Dec 7, 2011 | 07:54 PM
Rickman48's Avatar
Shouldn't have any 'fitment problems' unless you go over .100, and then there's ways around that.
Old Dec 7, 2011 | 07:55 PM
I agree with deltapace77 dont use too thick of a gasket measure deck height , piston dish, etc. to get your total real compression. If you decide to go to a thicker gasket and the intake does not match you can get it milled i paid 100 to get mine milled after i milled my heads .024 that was with an edelbrock intake though.
Old Dec 7, 2011 | 08:47 PM
Rickman48's Avatar
But you're adding space, not dropping the bolt holes lower!
Thicker intake gaskets and a heavier bead of silicone might be needed!
Old Dec 9, 2011 | 08:32 PM
friskyjake's Avatar
Thankyou fella,s for your advice I,ll pass on the info.
greenslade
Mar 29, 2011 03:56 PM
bobsrats
Apr 2, 2009 07:36 AM
tlucas07
Mar 23, 2009 11:40 AM
Redog
Sep 12, 2008 01:54 AM
