Help decoding body tag
Looking at car with body tag as follows:
ST. 70-33687. BF08294. 5DY
TR-930. 580 55 BN7
04E. 446383 600163
I understand some of this ,but a lot more numbers than I am used to seeing
Any help would be appreciated
TR-930. 580 55 BN7
04E. 446383 600163
You might want to post a good, clear photo of the tag as it is easy to make a mistake in reading it. I think I see at least one error in what you wrote, and some of the codes don't look like they're where they're supposed to be.
We can make out this much:
70 = 1970 model year
3 = Oldsmobile
36 = Cutlass Supreme V-8
87 = Holiday Coupe (2-door hardtop)
BF = Fremont, California assembly plant
08294 = Fisher body sequence number (you wrote "5DY here, and I think it should "BDY as it is, I presume, to the right of the 08294)
TR 930 = black vinyl bucket seat
04E = 5th week of April 1970 assembly date
Not sure what those number are to the right of the 930. To the far right of the second line are usually the paint codes, but there would be only two of them with "PNT" or "PAINT" usually at the far right.
The 55 is a paint code for Galleon Gold lower body color. The B by itself would indicate a black vinyl top. There is no "N" or "7" in a paint code according to my source.
No idea what the 580 is.
The two big numbers at the lower right are common on Fremont body tags and have never been decoded as far as I know.
3 = Oldsmobile
One of our members has created this great link to decoding cowl tags
http://datatagdecoder.com/_beta/form.html
Try it and then thank Chris for it
Larry
Larry
The "N7" you think you see to the right of the "B" is actually "PNT" meaning Paint. The "55" and "B" are the lower and upper body paint codes respectively. As explained earlier, the "B" actually indicates a Black vinyl top. If the car were a convertible, it would indicate a black convertible top. If a two digit number (like "55") replaced the "B" it would indicate a painted top.
I don't know what that "5" is above the "PNT".
