Heat riser
Old Sep 16, 2022 | 03:18 AM
Ray Dzi's Avatar
Heat riser
Guy's, check your heat riser. Mine was stuck shut or partially closed. Took a few days of spraying Kroil and tapping and prying.
Went for a drive and top end is so much better. Like new found horse power.
Old Sep 16, 2022 | 04:02 AM
Oldsguy's Avatar
Past Administrator
Good point. That thing will rust shut if not used often.
Old Sep 16, 2022 | 04:14 AM
JohnnyBs68S's Avatar
I remember dad spraying that thing down w/ WD40 nearly every spring to keep it working properly. When I put on dual exhaust back in the '80s, I just disconnected the spring so that it would stay open. I'm sure mine is rusted pretty solid by now, but at least its in the open position.
Old Sep 16, 2022 | 09:57 AM
If it stuck once it will stick again. Most of us gut the valve and braze over the holes.
Old Sep 17, 2022 | 12:11 PM
Oldsguy's Avatar
Past Administrator
https://classicoldsmobile.com/forums...le-one-166026/
I did that, look at the last post in the thread.
Old Sep 17, 2022 | 01:11 PM
Ray Dzi's Avatar
your link takes me to your air cleaner housing repair. Is that what you wanted me to view?
Old Sep 18, 2022 | 10:47 AM
Oldsguy's Avatar
Past Administrator
yeah, I took out the guts of the flapper style heat valve and everything associated with it. The only difference is that I tried to weld instead of brazing. I burned some mighty holes that day.
Tom Bilse
Jul 27, 2021 02:43 PM
matt69olds
Dec 22, 2020 07:57 AM
sam196370
Sep 18, 2012 10:00 AM
droptopron
Feb 27, 2012 07:12 AM
johnfharding
Feb 19, 2009 01:39 AM
