Harmonic balancer
Old Feb 14, 2017 | 03:55 PM
griffey57's Avatar
Harmonic balancer
I have a 57 olds that needs a harmonic balancer, too noisy driving it this way. Any leads greatly appreciated
Old Feb 14, 2017 | 04:48 PM
Tedd Thompson's Avatar
How is the harmonic balancer making noise? That is not the usual complain on a worn out balancer. Are you sure it is the balancer or is the water pump making that noise?.... Tedd
Old Feb 14, 2017 | 05:39 PM
jensenracing77's Avatar
X2. If you find you do have a problem with the balancer, it can be rebuilt.
Old Feb 14, 2017 | 05:42 PM
griffey57's Avatar
Old Feb 14, 2017 | 05:43 PM
griffey57's Avatar
It makes a clanking noise
Old Feb 14, 2017 | 05:56 PM
Has the rubber failed and the outer ring making noise? Maybe hitting/rubbing something? This sounds unusual to me but again, If you need it rebuilt here is who I would send it to.
http://damperdoctor.com/index.php?ro...mation/contact
Old Feb 14, 2017 | 06:07 PM
griffey57's Avatar
I can't tell, but it went out 25 years ago, and it sounds the same a loud clanking noise
Old Feb 15, 2017 | 07:49 PM
Well weather or not if it is or is not making noise a harmonic balancer with 60+ years of age needs to be rebuilt, rubber only lasts so long..... Tedd
Old Feb 17, 2017 | 01:34 PM
Ozzie's Avatar
If the bond is lost and use is continued the remaining rubber will be eroded away resulting in a lot of looseness between the ring and the hub. This can make noise. It is negligent to continue in this fashion and may damage the steel parts to an extent that they can no longer be rebuilt.
Old Feb 17, 2017 | 04:18 PM
griffey57's Avatar
Harmonic balancer
Thanks Ozzie, I appreciate it
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
