Fitech EFI Timing Control Help Request
Old Jan 27, 2020 | 06:01 PM
Bryan Burch's Avatar
1969 442
455, unknown camshaft, very lumpy, definitely not stock.
10" Hg max at idle, no vacuum leaks
Fitech Go-EFI 4 (30002) with FCC
Situation:
Ran OK for 2+years with no issues. I'm switching from vacuum advance to Fitech controlled timing. I've replaced the distributor with a MSD Chinesium clone (Pro-Comp) with locked out the advance. MSD adjustable rotor. I've switched timing control to VRCOIL on the hand-held and recorded it to the ECU. I've identified TDC and set the distributor to 10" BTDC, and set that in the hand-held as well. It runs. But it needs to run better.
What I need:
I need advice on how to get this thing dialed in. Suggestions, tips, tricks. I am working hard to get the rotor phased but I find myself without a second cap to cut a hole in for visual proof to see the sweep across the terminal. But what other settings should I consider in the hand-held? The Fitech documentation is thin. Does anyone have any written steps?
Old Jan 28, 2020 | 09:59 AM
Or, let's start with this, how do you determine what initial timing should be?
Old Jan 28, 2020 | 11:03 AM
VC455's Avatar
Barely Registered
Just follow some conservative guidelines.
First, and throughout your adjustment of initial advance, be sure your total timing stays at 35° or less.
A lumpy cam may idle better with lot of initial advance, perhaps 20°. See what it likes.
Keep your vacuum advance conservative, start about 10° coming in above 15 inches.
Make small changes against the clock and listen carefully for knock.
AndyG123
Apr 9, 2020 08:53 AM
Cutlass455
Mar 2, 2017 12:45 PM
D Appeldorn
Aug 29, 2012 06:28 PM
67Olds442X2
Apr 15, 2011 01:35 PM
silverriff
Mar 18, 2010 12:44 PM
