Exhaust pipe rubbing
Old Feb 25, 2013 | 06:10 PM
JR442's Avatar
I installed a new stainless X exhaust system on a 1972 442. I did increase size from i believe 2" to 2 1/2 inch. The exhaust pipe is hitting lower control arm bracket next to exhaust manifold connection. Thanks John
Old Feb 25, 2013 | 06:56 PM
You may need to finesse it a bit. Sometimes a simple bend or dimpling, and you may need a torch to heat it. Or you may need to grind a bit on the bracket, pic's might help.
Old Feb 25, 2013 | 08:21 PM
JR442's Avatar
Thanks I will go over options with brother, never thought of maybe grinding a bit. We did discuss dimpling, but wanted to do so without putting hole in pipe. My brother also thought of maybe putting a chisel between two to spread out. Were you talking about heating it before putting dimple in it. Thanks for your info and time appreciate it John
Old Feb 26, 2013 | 05:55 AM
I was talking about heating the whole pipe in an area and bending it over.
Old Feb 26, 2013 | 06:03 AM
krooser's Avatar
Hot Rod Has Been
Got a hammer?
Old Feb 26, 2013 | 06:04 PM
JR442's Avatar
thanks again
I talking about heating the whole pipe in an area and bending it over.
rmoths
Jul 9, 2014 03:26 PM
atkinsom
May 29, 2013 06:39 PM
805cut
Jun 8, 2012 03:15 PM
import extermination
May 17, 2009 11:07 AM
New'n72
Oct 3, 2007 02:36 AM
