Engine swap
Old Nov 18, 2014 | 04:22 AM
Bfg's Avatar
Bfg
Engine swap
Hello from Wonderful Winter Wonderland, I have a 1986 GMC half ton pic-up with the a Chevy 350 and Turbo 400. The motor needs a rebuild. Being a Olds guy I have a good running 1975 Olds 350 out of a rusted 88. Has anyone ever done a olds motor swap from a chevy? Thanks.
Old Nov 18, 2014 | 06:03 AM
halfmoontrail's Avatar
I don't have any specifics, but I've seen a number of earlier Chevy/GMC pickups with Olds 455s installed. I've seen it enough times to think that it might be a feasible swap.
Good luck on the project.
Steve
Old Nov 18, 2014 | 06:17 AM
Its been done numerous times. Do you have a bop transmission to go in there also?
Old Nov 18, 2014 | 08:08 AM
Yeah, GM did it when they put the Olds diesel in these trucks. Get the diesel frame mounts and any Olds motor drops right in.
Old Nov 19, 2014 | 04:25 AM
Bfg's Avatar
Bfg
Motor swap
Thanks for your input Joe! Other than motor mounts do you think all the wiring and linkage will hook up?
Old Nov 19, 2014 | 05:52 AM
All the linkages will be fine, just need to adjust accordingly. Minor wiring changes for starter and accessories that move from one side to the other. Use all the brackets from the engine your installing.
Old Nov 19, 2014 | 06:59 AM
Bfg's Avatar
Bfg
Engine swap
How would I know if it has has the BOP belhousing
Old Nov 19, 2014 | 07:20 AM
This is a Chevy
This is a BOPC
805cut
May 3, 2012 08:11 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
<maxone>
Nov 28, 2008 11:57 PM
ferg87
Aug 3, 2004 08:33 AM
