Engine Oil Supplement
Old Jan 29, 2021 | 02:06 PM
edzolz's Avatar
Found this can of unopened supplement
1#1052367
can says GM ENGINE OIL SUPPLEMENT (concentrate)
is this break in oil or stuff like the old STP.
Old Jan 29, 2021 | 02:14 PM
Apparently the old formulation is quite good, with both zinc and moly. The new stuff, less so. Found this from 2004:
Old Jan 29, 2021 | 02:55 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I used to sell that stuff back in the 60's when I worked for a Buick dealer. Really good stuff.
Old Jan 29, 2021 | 03:15 PM
Sugar Bear's Avatar
The EOS worked very well, used it with new cams, lifters etc. and to quiet old ones.
Top Engine Cleaner 1050002 was also fantastic. Got introduced to TEC after tuning and briskly test driving a '69 Chevy small block that started to knock. Old school service manager listened to it and said he thought it was carbon on top of a piston and to try TEC. It worked, crisis averted.
Old Jan 29, 2021 | 04:26 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The GM engine flush was also really good. The new EOS still has reasonable levels of ZDDP, I think it tested at about half that amount. Surprisingly enough we bought some of these products while working at a Ford dealer. Ford's glass cleaner was horrible, GM's was quite good.
Old Jan 29, 2021 | 06:49 PM
Run to Rund's Avatar
I use 1/2 bottle of EOS with Delo 400 CI4+ oil (old spec, not meeting CJ) in flat tappet engines with high spring pressures and cam lift rates.
Old Jan 29, 2021 | 07:31 PM
I use a full bottle of EOS and 4.5 qts of non detergent straight 30w to break in a FT cam and lifters.
Old Jan 30, 2021 | 05:58 PM
I like Comp 159 for break in, However, moly lube on the cam, lifters, and additive will plug the oil filter so don't run them more than the 20-30 minutes break-in time. The old formula EOS doesn't seem too bad that way.
My2nd 69 442
Nov 1, 2016 05:47 AM
scooter123
Apr 14, 2013 08:41 AM
Kid64
Jan 6, 2013 09:17 AM
phil tozer
Aug 3, 2011 11:54 AM
olds67
Dec 5, 2009 01:11 PM
