Engine Identification Help
Old Jun 17, 2017 | 03:23 PM
Portland68's Avatar
Hello everyone, new to the forums and hoping to get some information settled without breaking any forum rules.
I just purchased a 1968 GMC pickup with what I was told to be a 442 engine and transmission swapped into it. The only number I am seeing on the engine is 396026G, any information would be great!
Thank in advance
Old Jun 17, 2017 | 04:05 PM
rcorrigan5's Avatar
Randy C.
That would be a 400ci block out of a '68 or '69 4-4-2. If you look at the VIN code, stamped into the engine block onto a pad on the driver side just below #1 cylinder, the second number in that series will tell you the year. The number should read "3 (which means Oldsmobile), either 8 or 9, a letter or number (E, M, Z or 1), then six numbers. If the second number is an 8, the block came out of a '68. If it's a 9, it came out of a '69. The same number should be stamped into the transmission casing, be it a manual or automatic.
Randy C.
Old Jun 17, 2017 | 05:41 PM
svnt442's Avatar
It may not have been out of a 442. Remember the Vista cruiser was also an A body and that fell under the CID restrictions at the time of no more that 400 CID.
Either way it came out of an A body, but the trans can actually be more telling. If the VIN derivative match on the engine and the trans and the trans has a tag that would have come from a 442, then that could be proof, but if the tag is either missing, too worn to read or not from a 442, or possibly from a different car than the engine, there is no way to know for sure.
Old Jun 17, 2017 | 06:30 PM
Portland68's Avatar
Here's a picture I took of the bottom of the transmission, if you would kindly point me in the direction of the transmission tag I will update with what it says.
Old Jun 17, 2017 | 06:33 PM
wr1970's Avatar
on Drivers side of trans not on the pan.
Old Jun 17, 2017 | 06:53 PM
Portland68's Avatar
Looks like 26A238713
Old Jun 17, 2017 | 07:11 PM
svnt442's Avatar
Look here
Old Jun 18, 2017 | 01:26 PM
Portland68's Avatar
Originally Posted by svnt442
Look here
it looks like 76 PC 82972, does that mean anything or am I reading it correctly?
Old Jun 18, 2017 | 01:35 PM
Qwik71442's Avatar
Full-time Taxpayer
I believe the 76 PC came from a 76 455 Pontiac
Old Jun 18, 2017 | 02:08 PM
70W-32's Avatar
Yes, PC shows it is the code for a T400 originally installed behind a 455 Pontiac motor, and the 76 indicates it was a 1976 model year vehicle
Old Jun 18, 2017 | 03:33 PM
Portland68's Avatar
So with the casting number on the block it's looking like a 76 turbo 400 mounted to a 69 400 out of an A body that may or may not have been a 442?
Old Jun 18, 2017 | 03:56 PM
Correct.
laxs1308
Feb 5, 2019 08:14 AM
Scott183
Jul 20, 2016 08:35 AM
chris_harris11
Jun 28, 2014 02:15 AM
455Gbody
Oct 10, 2009 08:46 AM
airjester2000
Jul 31, 2004 12:45 PM
