Electric fan Ques.
Old Feb 19, 2010 | 08:20 PM
ELECMAN's Avatar
Electric fan Ques.
I bought a set of dual fans that are mounted to a shroud .I want to install it in my car . I have a stock alternator.I put a amp meter to the fans and looks like it draws about 10 amps I going to use these fan as a pusher in front of the condenser.Leaving the stock radiator which is a 3 core and using the fan blade and the shroud.The car runs at 195 normal operating .I'm going to install a thermosat with a probe to control the elec fans.How should I start wiring these fans with a relay etc etc.
Old Feb 20, 2010 | 06:29 AM
Lady72nRob71's Avatar
Do you know what alternator you have? If you have the 63A, then it should be fine.
If the car has AC, then it should be the 63A.
Are these fans single or dual speed? What did they come out of? One can get quite creative on the wiring. Does the car have AC? Do you have an extra plug/port in the radiator to insert a temp. sensor?
Old Feb 20, 2010 | 07:24 AM
ELECMAN's Avatar
I do have ac in the car.I bought the set of e-bay for about 60 bucks brand new.I can tell you they are loud.they are reversable fans they are single speed motors the thermostst control has a turn dial for temp and a probe that comes through the fins in the grill .I'm also putting a bypass switch to turn them on manually too.what are some of the wiring hints
Old Feb 20, 2010 | 08:29 AM
For starters, I see the need of multiple relays. First, i would wire the first relay just like the factory defogger, so the fans would only run while the engine is running. They will be hard on your battery. I did this with my car's seat heaters like this:
https://classicoldsmobile.com/forums...html#post57265
This switches the 12V side; fuse holder is mandatory.
The next relay would be connected to the temperature sensor.
A third relay's coil would be needed to connected to the A/C compressor clutch, to bypass the thermostat.
However, I do not like the idea of the fans running with the A/C if the car is at highway speeds.
Let me look in the service manual to see how my caddy is wired up...
convertible 63
May 9, 2018 06:10 AM
agtw31
Jun 23, 2009 01:39 PM
shaks 442 clone
May 3, 2007 12:36 PM
Redog
Dec 29, 2006 12:38 PM
Redog
Nov 9, 2006 05:41 AM
