Door sill plates
Most vendors sell usually two types,one is not quite like the ordinals, but are cheaper, and then ones that look like the factory. Without buying aftermarket, it will be hard to find any new factory ones. If you do find they will cost you a fortune.
I was looking at these ones.
https://www.trimparts.com/4150
Or get them thru summit which is a little cheaper.
https://www.summitracing.com/parts/oam-4150/overview/
If you want ones that have the correct look with the rivet, the Parts Place sells a set:
https://www.thepartsplaceinc.com/old...ID=4&year=1966
