Cruise Control?
Old Mar 14, 2012 | 03:46 PM
jag1886's Avatar
Cruise Control?
I'm getting my 65 ready for the road, does anyone have a source for a good after market cruise system for old cars. I have looked on the net and there doesn't seem to be much available.
Old Mar 14, 2012 | 03:54 PM
WoofWagon's Avatar
This might be the excuse you need to upgrade to fuel injection.
Old Mar 14, 2012 | 04:18 PM
Well, Perfect Circle was bought out by Dana, so you could check a number of their stores. I did a quick web search and came up with these:
http://www.ebay.ca/itm/1960s-70s-Dan...item3372efc3fc
http://www.thecruisecontrolstore.com...FQ2FhwodWiHDhQ
http://www.summitracing.com/search/B.../?autoview=SKU
Good luck with the decision. I have OEM for my car.
Old Mar 14, 2012 | 04:56 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a complete setup from an 86 camaro here if you feel like winging it.
Brake pedal with switches, vacuum ball, etc etc.
Old Mar 14, 2012 | 05:29 PM
DeltaPace77's Avatar
Why kinda late now, had an anused Compu-Cruise unit, I recently gave to another forum member. Pretty cool set up really, as was an LED display keyboard, with a driveshaft magnet assembly and in fuel line flow sensor. Cruise control, showed MPH, RPM, outdoor temp, MPG, the whole deal. Doubt these are made anymore, but maybe find one on e-bay.
Old Mar 14, 2012 | 06:01 PM
bigD's Avatar
yogi's in monticello iowa has what appears to be a pretty good set up, i am going to order one for granny in the near future...
Old Mar 14, 2012 | 06:47 PM
brown7373's Avatar
I bought one from JC Whitney, a Microcruise 4 in 2009. I installed on my Cutlass in a couple hours. It was pretty straight forward and works perfectly. It mounts onto the turn signal lever and has speed up and down and resume. It also used magnets on the drive shaft to sense the speed, and connects to both sides of the brake switch to cut it off when you touch the brakes. It has a servo that mounts on the left inner fender and needs manifold vacuum and connects to the linkage an the carb. It comes with an assortment of different pieces that lets you hook it to different applications. Price in 8/2009 was $229.99.
Old Mar 15, 2012 | 06:12 AM
jag1886's Avatar
Thanks for the responses, I found one built by Dakota Digital that looks like a pretty good unit.
Old Mar 15, 2012 | 08:49 AM
pcard's Avatar
70 Cutlass SX
Is this the one:
http://www.dakotadigital.com/index.c...d=46/prd46.htm
Please keep us updated - lots of pictures would be great!
Old Mar 15, 2012 | 03:43 PM
jag1886's Avatar
Originally Posted by pcard
Is this the one:
That would be the one.
Old Mar 15, 2012 | 04:39 PM
Looked at it. From the description and pics it should be a nice setup.
mruders
Feb 4, 2014 08:15 AM
bandit600
Jul 6, 2008 05:53 PM
ncwitte
Ninety-Eight
Apr 12, 2007 05:03 AM
Mr. King
Mar 28, 2007 06:26 AM
ztim
Dec 22, 2006 10:17 PM
