crack problems
Old Jan 24, 2015 | 02:36 PM
Octania's Avatar
crack problems
Intakes crack a lot, evidently.
Here is what happens to the block if the freeze plugs aren't enough protection.
Here is a 2-bbl that got ice in it I believe, now THAT is an intake crack.
Here is also a marine engine I dismantled a while back. Bad fire probably followed by water to put out the fire. I noticed the cam bearings were loose and FELL OUT when I removed the cam. Evidently the intake heated, expanded, and broke the block right down the middle.
Old Jan 24, 2015 | 03:21 PM
Stevec's Avatar
Holy s&@t!
Old Jan 24, 2015 | 03:27 PM
Old Jan 24, 2015 | 05:56 PM
don71's Avatar
same but different
Ouch!
That'all teach'em. Freeze plugs ain't going to fix that.
Old Jan 24, 2015 | 06:18 PM
seansolds's Avatar
I'd like to see FLEX SEAL fix that!
Old Jan 24, 2015 | 08:20 PM
Charlie Jones's Avatar
Phantom Phixer
Everybody calls them "freeze plugs" they are NOT.
The intended purpose of the holes in the side of the block was to support the inner sand cores during casting and to remove the sand after casting.
The proper term for them is "core plugs"
The engineers that designed these engines could have cared less about blocks breaking because someone left water in them during freezing weather. That is what ethlene glycol is for.
Old Jan 25, 2015 | 06:06 AM
It was actually an unintended benefit as a freeze would push them out as the water expands, sometimes saving the block.
chasman414
Jun 25, 2020 07:05 AM
malibu406
Feb 5, 2010 10:19 AM
my69olz
Oct 22, 2009 07:44 AM
Jamesbo
Dec 14, 2008 10:54 AM
Pitbull2o08
Jan 16, 2008 07:19 PM
