compressor belt alignment
Old Oct 30, 2022 | 09:23 AM
JAAMMS13's Avatar
I am restoring a 1971 Cutlass Supreme Convertible at first non of my belts lined up. Doing research and through OCA found out I had the wrong water pump. After changing water pump the power steering & alternator belts lined up but not the compressor. The A/C compressor is about a 1/4" to far out from engine, all brackets and mounting follow the assembly manual and my before pictures. I took my compressor to the parts store and compared pulley location to 2 new compressors and they were all the same. My pulley measures 2" from flat mount plate to center of pulley, how can I fix, is there a different compressor or pully clutch that will fix
Thanks in advance
I am located in Wisconsin
Anthony
Old Oct 30, 2022 | 09:40 AM
They lined up from the factory, so how about more info (engine, water pump, pulley numbers) and a couple of photos. It's hard to provide useful suggestions from the meager info you've provided.
Old Nov 1, 2022 | 08:55 PM
Bryan Burch's Avatar
Yeah lots of land mines there. Joe is right, but if you have the factory assembly manual, it has all the right configurations with nice little diagrams and pulley codes.
Last edited by Bryan Burch; Nov 1, 2022 at 09:07 PM. Reason: meant factory assembly manual, not CSM
Old Nov 1, 2022 | 09:08 PM
This is from my 69, so I'm not sure if it's exact. This all assumes you have the right water pump.
Last edited by Bryan Burch; Nov 1, 2022 at 09:09 PM. Reason: forgot about the water pump
Christopher Michael Drew
Jul 29, 2019 07:48 AM
steel
Oct 12, 2017 07:20 AM
sicky olds
Jan 8, 2013 11:10 AM
Rob delta
Dec 26, 2011 08:24 PM
TheRuss
Sep 22, 2008 05:45 AM
