Clearance Question
Clearance Question
Howdy. After a lot of grunting and groaning I have installed a 455 and TH 400 out of a 68 Delta 88 in my 67 F85, I used a edlebrock performer intake and stock Q jet carb. With a 2 inch tall air cleaner, the hood hits the cleaner. I used small block motor mounts, there doesn't appear to be enough clearance between the oil pan and cross member to use big block mounts. Would a different oil pan enable me to use different motor mounts? All proven suggestions would be appreciated!
Performer ? Or Performer RPM ?
Edit: Derp.
Fun71 teached me that RPM is small block only. Kindly disregard. I'll crawl back to my SBO world now....
Edit: Derp.
There is no dimensional difference between a SBO and a BBO below the heads except for the deck height, so changing to BBO mounts will not change the distance between the oil pan and the crossmember.
If you want an open element air cleaner that will work on your car, use this one.
http://www.ss396.com/part/ATE-3907.html
I used a factory drop base and that made a big difference. Then put a K&N filter top on it and you can only do this if there is no hood insulation. That all cleared well and gave it lots of air. I had the inner fender out on the passenger side so could see the hood to air cleaner clearance well.
jeffs 89 cutlass salon
Oct 19, 2007 08:42 AM
