Choke setting
Old Sep 17, 2017 | 06:19 AM
truckman5000's Avatar
W30
Choke setting
70- 455. w-30
Having issues trying to get the choke to open all the way.
The carb is factory with the heat crossover tubes, but the heads have the heat crossover ports plugged/ blocked. So obviously the heat tubes arent getting hot enough to open the choke.
The f-w30 heads are blocked from factory i thought so..
Old Sep 17, 2017 | 07:48 AM
You thought wrong. Run of the mill heads have BOTH center exhaust ports connected to the crossover, which disrupts flow. The W heads (D, F, etc) have only one port connected. There is still flow through the intake. Your blocked crossover is obviously why your choke doesn't open. Convert to electric.
Old Sep 17, 2017 | 08:05 AM
tru-blue 442's Avatar
Old School Olds
I have this one if needed. Original GM part.
Old Sep 17, 2017 | 08:56 AM
W30
Thanks guys, Thats what i was thinking. The original carb on it had the choke removed.
Thanks for the offer True blue, the carb that is on it isnt # matching so ill get a generic one.
240 Gordy
Oct 11, 2020 10:04 AM
Red Delta
Oct 25, 2009 05:03 AM
Olds64
Aug 25, 2009 09:22 AM
1973olds98
Aug 24, 2009 07:05 AM
dynamic88
Brakes/Hydraulic Systems
Aug 3, 2007 08:45 PM
