Best quality points
Old Jan 30, 2014 | 04:17 AM
tru-blue 442's Avatar
Old School Olds
Best quality points
The subject has probably been
beat like a rented mule. But does anyone
have a supplier besides the A/Z, C/Q
etc. for a quality set?
Old Jan 30, 2014 | 04:46 AM
mike8162's Avatar
I've always liked Echlin points from NAPA. They seem to have a stronger spring than the AC points. I've never used points from one of the performance suppliers but then my car never even comes near the redline.
Cheers, Mike
Old Jan 30, 2014 | 05:24 AM
Old School Olds
Thanks Mike, I'll give 'em a run.
Anyone eles?
Old Jan 30, 2014 | 05:32 AM
66-3X2 442's Avatar
Accel,Standard Ignition Performance series,Mallory etc. Standard Ignition has a distributor cap with copper contacts FYI.
Old Jan 30, 2014 | 05:48 AM
I've always liked the Blue Streak line from Standard - they were always better constructed (I haven't seen new ones lately, though).
Whatever brand you use, it's usually best to buy NOS (American-made) if you can find them, rather than brand-new manufacture, which is probably Chinese.
Old Jan 30, 2014 | 05:52 AM
Look for points for a Vette, higher spring pressure.
Old Jan 30, 2014 | 05:58 AM
Old School Olds
Thumbs up
QUOTE=oldcutlass;647997]Look for points for a Vette, higher spring pressure.[/QUOTE]
, nice. Thanks Eric.
Old Jan 30, 2014 | 06:20 AM
BUT, remember that the rubbing blocks of those points will wear faster, requiring more frequent adjustment.
Old Jan 30, 2014 | 07:12 AM
Old School Olds
That is also good to know too Eric, (other).
For as much driving it as I do, maybe 150-200 mi
a month at the most on an average, the Vette
unit may work out well for me.
I do admit I am a fan of points and condensors
on my older, Olds iron.
You would think I would know which is best.
Old Jan 30, 2014 | 07:22 AM
R-body_mopar's Avatar
Exclamation
I always used Mallory 102X points and Mallory 401 condenser. Had great luck with them for both wear and stability at higher rpm's. As stated above, be sure the rubbing block is clean and well lubed with the proper Delco cam lube (if it is still available....lol!).
I have a set of these new in box NOS Mallory, if you are interested! Shoot me a PM!
Note: these parts are NEW...and probably over 30 years old....pretty sure they are not made in China!!
Old Jan 30, 2014 | 07:38 AM
Old School Olds
PM sent bud, and thanks, Adam.
Old Jan 30, 2014 | 08:20 AM
Note that the difference between "regular" points and "Corvette" points is that the Corvette points have a stronger spring, which moves up the speed at which the points begin to float by a thousand or so RPMs.
If you are using a more-or-less stock Olds engine and transmission, which is shifting at around 4,500 RPM, you won't gain any benefit from these, but if you are pushing it to 5,000 you probably will.
If you are going above 5,000 RPM, it is probably advisable to get an electronic unit, of whatever kind, as this is where points begin to show their inherent weaknesses.
There is nothing wrong with using the stronger-spring points on other engines, except, as I mentioned, that the stronger spring pressure will cause the rubbing block to wear a bit faster.
Originally Posted by R-body_mopar
... be sure the rubbing block is clean and well lubed with the proper Delco cam lube (if it is still available....lol!).
I don't know about Delco, but the higher-quality points used to come with a tiny dab of cam grease in the package.
If you need more, Summit has Mallory cam lube grease, and Bosch cam lube grease (#5 700 002 005) can be obtained easily from various German-car aftermarket suppliers.
Old Jan 30, 2014 | 09:53 AM
Old School Olds
Great info guys.
And yes 66 3X2, I use the
Standard cap and rotor
with the copper contacts.
These type units have worked very
well for me over the years.
No way would I spin this one up past
5K... Well, maybe once in a while, it is
an E block.
Old Jan 30, 2014 | 10:05 AM
brown7373's Avatar
I used to have good luck with Accel. I used the heavy springs on my 69 Corvette, because the std. spring points wouldn't let my engine rev to the 6000 rpm redline. But the rubbing block, even with grease, wore out in 2-3000 miles. Heavy spring does nothing for 0-5000 rpms. Also, the heavy spring is also harder on the distributor shaft cam that opens and closes the points. I had one break loose and needed to replace the distributor.
Old Jan 30, 2014 | 11:57 AM
As stated, the NAPA Echlin points and Standard Ignition Blue Streak points are (at least were) the better quality parts and therefore cost a bit more. Way, way better quality than the cheaper points.
Back in the day I worked at a NAPA store and learned that the NAPA/Echlin points were the same as the Accel points. There were "Street" points with 23 ounce springs and "Performance" points with 32 ounce springs. Don't know if that is still the case today.
Anyway, I used the Echlin 23 ounce Street points (they were cheaper than the 32 ounce Performance points) and would take the spring from my old set and add it to the sew set. With the stiffer double spring, the points would go to 6000 RPM with no bounce.
Old Jan 30, 2014 | 12:02 PM
billmerbach's Avatar
major noob
I have a set of bravo and blue streak for sell
Old Jan 30, 2014 | 12:04 PM
major noob
The bravo comes with a condenser
Old Jan 30, 2014 | 12:27 PM
Speaking of 400 E blocks, what IS the top end on those?
The Rallye Pac I have for the car, which came from a different car, has no red line on the tach.
I seem to recall WOT throttle 1st into 2nd going right when my friend yelled let off on the first time we drove it.
Old Jan 30, 2014 | 12:51 PM
I'd keep it around 5k.
Old Jan 30, 2014 | 03:30 PM
mpolds's Avatar
The best set of points on the planet.....
The best set of points on the planet forever has been the Standard BLUE STREAK points -- which is all copper contacts, has the screw for adjustment, and has the additional little brakcet with a "wick" -- keep it "wet" with cam lube and you'll never need to rebuild a distributor....
Standard discontinued making the BLUE STREAK line 2 years ago -- but I still have plenty...............
Give me a call -- Craig -- 516 - 485 - 1935.... New York.....
Old Jan 30, 2014 | 04:37 PM
Old School Olds
I DO remember those, I had just
forgot who made them.
Thanks Craig, message sent.
Old Jan 30, 2014 | 06:53 PM
mpolds's Avatar
response
This is Craig's friend who asked him to post this.
You forgot to leave your phone number. I got your message. Give me a call in the morning 5164851935.
Thanks.
Old Jan 30, 2014 | 07:38 PM
Years back in a discussion with someone on ROP (can't remember who right now) the fella said he routinely brought his to 6500. Forged steel crank and short stroke makes high RPM attainable.
Old Jan 30, 2014 | 07:43 PM
Old School Olds
It sucks Olds only made the 400 E
for two years. The 66 coupe I had
years ago would run circles around
the one I have in the vert, strange.
Old Jan 31, 2014 | 03:06 PM
marxjunk's Avatar
wow..not a mention of Borg Warner HP points...by far the best points ive ever used..as far as reliablity and durability
i have TONS of NOS points..BW Accel...GM....and a bunch of american made stuff
Old Feb 2, 2014 | 03:20 AM
Exclamation
I had a 1970 442 455 W-30 4spd back in the day, and routinely brought that up to 6000 or more, but bent a few pushrods in the process! Lol!
Pulled the engine and rebuilt it....and used better parts......could crank 6500 or more......but probably should not have.......BUT...it sure was FUN!
A buddy of mine bought a 1967 442 post coupe NEW, special ordered with wide ratio 4spd, and 3.55 anti spin rear end and stripe delete.....sure surprised the crap out of many a Chevy....!! The post coupe is much more stable than the hardtop or convertible......!
tru-blue 442, PM has been sent! Thanks!
Old Feb 10, 2014 | 09:52 AM
Question
Just a bump to the top, as I have not heard from you, Adam! Wondering if you still wanted these?
BeenThere
Nov 22, 2013 09:47 AM
soundhd
Aug 8, 2012 04:24 AM
navvet
Feb 11, 2012 01:16 PM
69350rocket
Body work
Jul 19, 2011 04:14 AM
dingusboy
Care and Appearance
May 17, 2009 12:14 PM
