Bendix treacle vac
Old Jun 2, 2017 | 10:24 PM
griffey57's Avatar
Bendix treacle vac
My power brake unit is failing on my 57 olds. I just had it rebuilt 4 years ago, it cost me $500 dollars. I am debating whether to rebuild it or replace it with a conversion
Old Jun 2, 2017 | 11:27 PM
59-59-59's Avatar
$500 4 years ago? You got ripped off. If the unit is actually bad, send it to Ed Strain in Florida to be rebuilt. He is listed in Hemings, along with other publications
Old Jun 2, 2017 | 11:28 PM
griffey57's Avatar
Thanks for the info
Old Jun 3, 2017 | 06:37 AM
"Treacle vac"?
You mean one of these?
Old Jun 3, 2017 | 07:05 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I had the one on my 54 rebuilt by Karps in Upland, CA. I have been very satisfied. It was about $500-$550. Jeff is a good guy and has been in the business a long time. Here is the link.
http://karpspb.com/
Old Jun 3, 2017 | 09:07 PM
griffey57's Avatar
thank you
Old Jun 4, 2017 | 03:24 AM
flatoz's Avatar
I got rid of mine even after having it rebuilt and not being happy with the brakes. Plus I like the belts and braces idea of a dual master cylinder. Of course if you're going full points resto that won't work. But I also know I drive my car everyday, so my near misses are multiplied beyond just a Sunday cruise.
G body assemblies will work, again , not stock but guess it depends on how well you want to stop.
Old Jun 4, 2017 | 04:21 AM
tommieb's Avatar
Oh no
Drop that unit go with Power disc brakes. Don't ask me why?????????
Old Jun 4, 2017 | 06:16 AM
Tedd Thompson's Avatar
I drive mine all over the Western US and Canada with no issues that would make me change to disks. No doubt disks are a better system or the auto industries wouldn't have changed to it but mine are set up to slide the wheels if I have to in a panic stop. That's good enough for me, it's a classic not a Honda cevic.... Tedd
Old Jun 4, 2017 | 07:19 AM
griffey57's Avatar
Thanks, no full points resto, I drive her once a week and enjoy it. They are made to be driven
Old Jun 26, 2017 | 10:57 AM
supmarjo's Avatar
hi i just went thu this this last year. Had a guy up in Sacramento area rebuilt it.. did not hold up ,was leaking so i took it apart, and found it was a Bad rebuilt.
ended up installing a under floor master n booster,w remote res.
got the idea here..Olds Dad under floor power brakes 1955..
w disk brakes kit from Scarbird
system works very good
Old Jun 26, 2017 | 11:25 AM
griffey57's Avatar
Thanks, I am going to switch over as well.
Old Jun 27, 2017 | 12:35 AM
flatoz's Avatar
check out the conversion I did, just search my name for posts ( not that many ) on the engine swap I did, I showed what I did there. I've seen underfloor units, but the idea of bleeding them etc I didn't like ( each to their own) My car as I said previously is a daily driver so I can say the swap works well.
I actually have drum brakes soon, I've just had a scarebird disc setup finally sorted out as it didn't fit like it should, so in the next month or two I will put that on too. Given the nuts traffic I encountered when in CA last year I can understand wanting better brakes.
Rocketowner
Nov 11, 2014 12:54 PM
1970VistaCruiser
Jan 15, 2013 06:16 PM
1970VistaCruiser
Nov 22, 2012 04:55 PM
PushRod
Brakes/Hydraulic Systems
Mar 30, 2010 01:53 PM
lowdynamo
Dec 8, 2008 04:48 PM
