67 Cutlass with a shaker FAIL.
Old Aug 21, 2020 | 04:11 PM
Coastie's Avatar
Stock cars are too boring
So im currently rocking a bolt on cowl hood scoop on my 1967 Cutlass. I'd like to mix it up and add a shaker. I've got a spare 67 hood, and a scoop from a 2nd gen trans am. Anyone done this before? My first attempt went less than desired... So im pretty much gonna abandon this idea unless someone else knows some tricks. (Don't worry, the cowl scoop hides the make shift cuts)
If anyone needs a clean 67 hood or a late 70s trans am scoop, I've got one in Michigan lol. I'd happily trade it for a fiberglass cowl hood.
Old Aug 21, 2020 | 05:05 PM
RetroRanger's Avatar
72 Olds CS
no wonder its a fail your shaker is backwards
turn it around FTW
Old Aug 21, 2020 | 05:23 PM
Lonnies Performance's Avatar
Honestly I think it will look poor, especially since the engine is not centered left to right. Also unless you have the means to put a nice rolled edge on the cut, it will look unfinished.
You would be better off selling a nice factory hood & spending that money towards a GOOD quality fiberglass hood. Notice I stressed good, as there are more
junk brands than good ones out there.
Old Aug 21, 2020 | 05:27 PM
Coastie's Avatar
turn it around FTW
That was the original plan, definitely won't fit that way
Old Aug 21, 2020 | 05:28 PM
Coastie's Avatar
Thats what im trying to do
Old Aug 21, 2020 | 05:55 PM
You do realize that the shaker goes the other way, right? As you have it, the opening is pointed at the low pressure area caused by the air going up over the leading edge of the grill. It faces backwards specifically to pull air from the high pressure at the base of the windshield.
Old Aug 21, 2020 | 06:06 PM
Coastie's Avatar
Yes im aware; I traded a 79 trans am for the cutlass. Unfortunately the engine sits so far back that to put it on correctly, I'd have to cut the rear of the hood off.
Old Aug 21, 2020 | 06:35 PM
cherokeepeople's Avatar
oldsmobile/shaker hood=wrong
Old Aug 21, 2020 | 06:51 PM
Coastie's Avatar
Gonna have to disagree with you.
Old Aug 21, 2020 | 06:59 PM
I can appreciate the workmanship, but not the aesthetics. Sorry, but a single shaker on a "double hump" hood just doesn't look like it belongs. Now, the 67 and 68 hoods are a much better fit to using that style shaker. I added an L88 scoop (which is a similar shape) to my first 68 442 (using the "flat" hood from a wagon) and it actually blended with the lines nicely.
Old Aug 22, 2020 | 07:42 PM
oldolds88's Avatar
where in michigan are you?
Old Aug 23, 2020 | 07:05 AM
agree,the flat hood would pull it off way better.
Old Aug 23, 2020 | 10:55 AM
Coastie's Avatar
Detroit area.
irkennedy
Apr 26, 2020 05:50 AM
joe68h/o
Dec 6, 2017 07:51 AM
Delmont 88 PA
Dec 17, 2012 05:27 PM
67Olds442X2
Body work
Mar 5, 2012 05:24 PM
nonhog
Jan 1, 2012 08:55 AM
