455 year differences
The mounting hole for the clutch pivot ball was omitted in the later years. I think it’s a myth, but supposedly the earlier blocks had better metallurgy. Unless you need the pivot mount, any 455 block is going to be adequate for 95% of the Olds guys.
To the OP's question, the big external difference, as noted, is the missing hole for the clutch Z-bar pivot ball on the FA blocks. Other than that, the blocks, cranks, rods are all interchangeable. Olds varied CR with different size piston dish, and obviously the cams changed depending on the year and application. Nearly all BBO heads will flow the same if you install the same size valves, except for the "J" casting heads used in the 1973-76 model years. Stock 4bbl intakes (even the aluminum W30 intakes) have pretty much the same runner design, with the exception of the Toronado intakes with the depressed carb for hood clearance. Exhaust manifolds go with the chassis that engine was installed in.
This is a technical detail, but a 69 Cutlass would not have a 455. Prior to 1970 the 455 was used in the big cars. The only Cutlass to get the 455 was the Hurst Olds.
The metallurgy is a myth. Why would this ONLY apply to 455 blocks and not other Oldsmobile blocks?
I did say I doubt there is any truth to the myth.
Anyone in readerland know WHERE the myth originated? Same with the solid main web 403 myth. Just curious, most rumors and myths have their origins with factual information. Curious if anyone knows where they started.
