455 engine ques.
455 engine ques.
The previous owner of the car had his mech put a 455 motor in the car.it originally had a 350.he used the exhaust manifold's from the 350 motor.he blocked off the down pipe hole when using single exhaust.is this a bad thing and can this cause the exhaust manifold gaskets leak.
An engine is a air pump. You have to get air in and out efficiently. When you block the exit you can't get air in because the exhaust is still in there with nowhere to go. A very restictive exhaust can easily cut 100HP or more out of the power you are making.
THE LEFT MANIFOLD HAS A bIG #1 380001 GM ON IT AND THE PASS HAS A BIG # 4 ON IT IS THIS A 350 EXHAUST MANIFOLD.IF I WOULD PUT THE CORRECT EXHAUST MANIFOLD,S ON WILL THE EXHAUST SYSTEM HAVE TO BE ADJUSTED AND IS THERE MAYBE A KIT
I am about to get a new exhaust system on my 455 and after doing a ton a research on headers and decided not to get them and just stick with my stock w/z manifolds. I read that unless you spend a pretty penny on the headers, any cheaper headers are going to require some modification of either the frame or headers themselves, just because the fit isn't so good. Take a look at some of the other forums on here and read some of peoples personal expeiren es.
get rid of that whole exhaust system and go 2 1/2" all the way back.
i bought some dynomax ceramic coated for my 72 U code 455 ragtop years ago,i didnt have any problems installing them.
my brother has Hookers on his W-31,they fit perfect.
only problem with headers is blowing an exhaust gasket out now and then,if the flange isn't perfectly straight.
