19" fan.
Old Oct 14, 2015 | 04:24 AM
tru-blue 442's Avatar
Old School Olds
19" fan.
I have a fellow interested in a fan and clutch I have for sale.
Does anyone know if the 19" fan will fit a 68 400 without air
but with original fan shroud? Car is a 68 Cutlass with a 350 in it now.
They will be dropping in the drivetrain from a 442 in soon.
My gut says yes, but I could use your advise, thanks.
I don't know if he will be using frame pads and mounts for a 350
or ones for a big block. This may be a concern...
Old Oct 14, 2015 | 12:39 PM
Old School Olds
Anyone? Curious as to the fan size on the 68 Cutlass with a 350.
Basically the question is a bump guys. Thoughts at all? Perplexed,
I think it should work on either but I'm a big block kinda guy too,
so I can't say with any certainty.
Old Oct 14, 2015 | 01:54 PM
oldspackrat's Avatar
I think there were 2 fan sizes, 19 1/2 & 19" so I think the smaller of the two should work but this is purely a guess.
Old Oct 14, 2015 | 02:03 PM
Old School Olds
Thanks Scott. I always thought that the 19's were the ones to use
if you can find them, for use on the 68-72 V-8 A body anyway.
Old Oct 14, 2015 | 05:47 PM
Yellowstatue's Avatar
On the question of motor mounts, I placed four big block mounts and four small block mounts on a level surface and they were all the same size. The only difference I could see was that the big block mounts had the interlocking metal surfaces that would prevent the engine from moving if the rubber broke.
cdoering
Mar 9, 2015 03:38 AM
67442nut
Dec 7, 2014 06:40 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
agtw31
Jun 23, 2009 01:39 PM
