Voltage regulator buzzin
I installed an MSD HEI Pro Billet plug and play distributor on my 68 442 BB 400. When I put the car in gear the GEN light comes on and I can hear the voltage regulator buzzing, as soon as I give it some gas buzzing stops and light goes out. I have the original alternator that has been rebuilt and a new stock voltage regulator I have the idle set at about 950 to 100 that seems to be where the cam likes it. Do I need to run a different alternator or voltage regulator or both
OK replaced the voltage regulator with an A/C Delco D663, ground checked out good and battery tests good but light still on dimly and voltage regulator still buzzing at idle when car is warm. Do I need an alternator with higher output and if so what output should I go to? I have found some on line that can putout up to 120 with out modifying or changing the stock wiring harness.
delta_88_germany
Feb 22, 2014 01:48 PM
