rally pack installation help
Can someone, perhaps, please give me better instructions than those provided with the '68 442 Rally Pack from The Parts Place? They come close to the horrible instructions provided with some of the Made in China shop equipment I've purchased.
Trying to put this in now, so the sooner the better.
Thanks!
Thanks!
The wiring for the guages in the dash plug are in different order than the idiot lights...same wires, different order...see chassis manual page 15-31 fig. 15-59...disconnect pin from plug, change position (not your chair) plug and play
if you guys keep pickin' my brain I am going to have to get a refill..
WOW - you got instructions with yours?? I didn't... Of course it sounds like it would not have mattered anyway.
Yes the pins in the connector need rearranging, which is easy to do and nondestructive. You add a new wire for tach and change the oil and temp sensors.
Post back if you still need help on the wiring. If you have a factory wiring diagram, it will be shown there, too.
