Neutral safty switch problem
Old Jul 18, 2025 | 06:19 PM
Joe 442's Avatar
On my 71 442 with automatic transmission, I replaced the neutral safety switch . New switch acts the same way. It works once, then it doesn't Adjusting it does not make it work every time. Could the back drive linkage have too much slack in it. I get it working in park , reverse and neutral, then I drive it and it seems to be out of adjustment again.
Old Jul 18, 2025 | 08:05 PM
What happens if you jumper the switch when it won’t start? If it starts, you may have to readjust and find a happy medium.
Old Jul 19, 2025 | 06:55 AM
Is this a column shift car, a factor floor shift car, or a former column shift car converted to floor shift? Is the backdrive linkage properly installed and adjusted FIRST, then the NSS adjusted?
Old Jul 19, 2025 | 09:26 AM
Joe 442's Avatar
Neutral safty switch on 71 442
This is a factory duel gate car with stock back drive that has never been changed. The back drive does have some slop in it that could be causing the erratic behavior of the switch.I would not think the switch would be that picky, it would be set for park and reverse, and the rest should line up.The next time it is put back into park it is out of adjustment again. That is why I think there is slack somewhere.
Old Jul 19, 2025 | 01:36 PM
cdrod's Avatar
Rodney
1971 model year should have the NSS switch mounted to the steering column. Try this: grab the steering column just forward of the turn signal stalk, and rotate it CCW before starting the car. If this fixes your problem, the back drive linkage is misaligned.
Rogan
Aug 17, 2023 06:36 PM
riskyb
Jul 30, 2021 03:15 AM
big man
Jul 16, 2021 09:57 PM
James Wilson
Mar 6, 2013 12:57 PM
jwavanlaarhoven
Dec 30, 2009 05:31 AM
