internal or external regulator
If you have an actual 442 it will have in internal regulator. All others came externally regulated.
Internally regulated alternators the 2 wire plug is on the edge of the case and the terminals are oriented like this - - . On externally regulated alternators the plug is on the back and the terminals are oriented like this | | .
i have a real 442. but the engine i got with the car is a 71 olds 455 out who knows what. i am not sure if they switched the alternator or not. now from the look of it they did. it came with a regulator mounted on the firewall, does this have to do with this or is that separate. basically who ever had the car a while back hacked it together and i believe they used it as a race car.
What is the VIN? It is a lot of work to swap to an externally regulated alternator from and internally regulated one because the harnesses are different.
What the engine came out of is irrelevant. There would be no need to change the wiring with swapping an engine unless you were going to a different family of engine I.E. Olds to Chevy.
Well somethings not right. You don't have a good pic of the alternator but I can clearly see the regulator on the firewall.
I can't believe that someone would go through all the trouble of going back to an externally regulated alternator buy switching the harness over.
Can you get a pic of both the cowl tag and the VIN plate?
the best way to tell what type of alternator you have is by the colors of the wires going to the alternator.
there was a transition period when they were switching/standardizing alternator cases. the case i see in the pic *looks* like a 10si case, judging by the ribs in the stator end frame. but, they used the same case, and iirc, the same connector shape - - on externally regulated alternators, during the transition period. i have one of these "transition" alternators laying around somewhere. there is no regulator inside, just a plastic spacer block to accommodate proper mounting of the brush holder assembly(10si style).
bill
bill
bill
bill
the vin is 344870M245877
i got numbers off the alternator as well
1102439 55
2811 12VNE
also just so you know this car is the equivalent of Frankenstein. when i got it had a 71 455, th350 (idk what year or what its out of), and a 1969 gto 10 bolt posi rear. also the car has been painted blue. the original color from what i can tell was the 78 code burgundy. i found it in the factory overspray locations and behind the undercoating in the wheelhouses. but the blue is in spots i dont think they normally would have painted if they didnt take the car apart to paint. my guess is it has been apart before.
hope any of this helps
also i have a buildsheet for the car with 34487 on it. ican dig it out and take a picture if it would help.
thanks again
1102439 55
2811 12VNE
thanks again
That's an externally regulated alternator for sure due to the orientation of the terminals. That car came with an internally regulated alternator so at some point the harness was changed for some reason. My guess was there may have been a fire under the hood or something to warrant the change and they probably junk yarded a harness and this is what they could find.
there is the transition alternator, externally regulated, as stated above. my bad on the terminals, was going from memory of about 20 years ago. notice the markings at the connector opening, there is both sets of terminal markings(1 & 2 and r & f). you could have that alternator rebuilt as a 10si.
bill
bill
You also have a 71/72 drivers side fender on the car so as mentioned there may have been some damage up front at one time or another. based on your cowl tag your car was built 2nd week of January 1970 so the alternator would have a number more like 9L9 or 9M31 for a November 9, or December 31, 1969 date. I believe they skipped I for the months thus J is for September.
thnkas for the help i will start looking for an alternator then
danlonchar
Oct 2, 2010 12:34 PM
