Grounded relays
Old Jan 1, 2008 | 04:28 PM
Chumley's Avatar
Grounded relays
After pulling my power brake vacuum booster for painting, I decided to clean up the top portion of the firewall and paint it as well. Question: Do the horn relay and voltage regulator mounts need to have bare metal contact when they are installed to the firewall? There is what I believe to be an engine ground strap that goes under one of the voltage regulator attaching screws. I know proper grounding is important and want to put everything back right. Also, how many grounding straps are there, and where are should they be located? '72 Cutlass, but with a '73 engine. Thanks, Chumley
Old Feb 20, 2008 | 10:13 PM
Jim's rare 80's Avatar
Jim's rare 80
Wow.
I'm suprised you didn't get a response to this. Yes they need to be grounded.
You can paint the firewall. The relay will ground through the screw.
A little tip, put a shakeproof washer between the relay and the firewall. It will ensure a good ground, and help secure the relay from being loosened when you're under the hood doing other things.
Jim.
88hurstolds
Aug 11, 2015 02:42 PM
1977 Delta 88 Flint
Dec 25, 2012 04:23 PM
jscottsanders
Nov 28, 2012 06:57 PM
Olds Dad
May 2, 2012 12:55 PM
65 starfire
Jan 19, 2008 09:22 AM
