ELECTRICAL
Old Mar 27, 2004 | 12:09 AM
NV WIDOW's Avatar
Post
WHAT IS THAT BLACK RELAY LOOKING THING WITH THE BIG PURPLE WIRE GOING INTO IT.RIGHT BETWEEN THE FUSE BLOCK AND THE DIMMER SWITCH.IT IS A 74 CUTLASS SUPREME (442).THE REMOVEABLE PART IS NUMBERED ON EACH OF THE FOUR PRONGS?????????
Old Sep 1, 2004 | 04:34 AM
Oldsguy's Avatar
Past Administrator
Post
NVWindow, on older cars like mine, purple is usually for primary (12 volts), or sometimes pink. If it goas to your dimmer switch, I would guess it is your unswitched 12 volts but I am not sure. If you say big meaning larger guage than the others this would lead me to think that even more so. Can you get a voltmeter to check that? Or do you have a friend that can help you? That would be best. What is your trouble?
supreme3.4dohc, what kind of question do you have about the alternator?
Don Bunnell
May 5, 2006 12:51 AM
jf857
Apr 28, 2006 07:24 AM
BOB W M
Apr 7, 2006 06:30 PM
PetChemMan
Dec 15, 2005 04:15 PM
86in
Feb 9, 2005 09:49 AM
