Alternator Whining
Old Oct 25, 2011 | 08:44 AM
Joffroi's Avatar
Runner
Alternator Whining
I started hearing a loud whining from my alternator when my car is running. The belt looks to be pretty tight, so I think the bearing internally are just going out and I'm going to need a new alternator. Are there specifics I need to look for as far as amps its generates? Any brands I need to look for? I dont really care about complete originality.
I drive a 1968 Cutlass with the standard 350 engine, no extra bells and whistles.
Old Oct 25, 2011 | 08:49 AM
rustyroger's Avatar
'87 Delta 88 Royale
You probably don't need an alternator much above 65 amp output.
If you are a competent shade tree mechanic you can replace the bearings in the alternator you already have, I'm not sure the job would be much cheaper than replacing the whole thing though.
Roger.
Old Oct 25, 2011 | 10:17 AM
atkinsom's Avatar
Before you do anything check out this old thread of mine. We replaced the alternator belt and tightened it very snug. Problem disappeared for a bit and came back ever so slightly. Water pump belt looked fairly new so we tightened that as well. Problem solved.
https://classicoldsmobile.com/forums...ing-sound.html
Old Oct 25, 2011 | 03:44 PM
My442's Avatar
Rebuilding an alternator is super easy.
There are kits to do it for low $$$
Also super easy: starters, power steering pumps
Do it yourself.
Old Oct 25, 2011 | 06:52 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a few of those externally regulated alternators laying around that I will never use. Shoot me an offer if you want a used one for extra parts.
F85_Inliner
Feb 6, 2014 06:48 PM
Odmark
26
Apr 12, 2013 06:27 AM
hunter
Nov 18, 2011 11:45 AM
Joffroi
Nov 3, 2011 12:42 PM
ls442
Jul 12, 2009 01:29 PM
