1956 Brake Light Problem
Old Jul 30, 2014 | 02:54 PM
tricordati's Avatar
I have a 56 88 and the passenger-side brake light does not light (but the tail light filament does when the headlights are on). Replaced with a new bulb but still doesn't light. Any suggestions would be most appreciated.
Old Jul 30, 2014 | 04:43 PM
Rocketowner's Avatar
The bulb should be a double filament bulb(# 1034 or #1157). One filament lights the brake light and turn signal, and the other work the taillight. Hope this helps. Larry
Old Jul 31, 2014 | 06:15 AM
tricordati's Avatar
Yep I did replace the existing with a double filament bulb, but still no brake light.
Old Jul 31, 2014 | 06:37 AM
The contacts are spring loaded and sometimes get corroded and stuck in place. Make sure it is free and the contact moves in and out freely. I've also found that the receptacles wear over time sometimes allowing the lamp to be put in 180 out which causes a misalignment of the contacts. Lastly use a test light to verify there is voltage.
Old Jul 31, 2014 | 08:13 AM
tricordati's Avatar
Thanks so much for those suggestions. I will try them this weekend.
72cutlassdog
Jul 9, 2013 05:46 AM
cobalt
May 4, 2013 08:45 PM
cobalt
Feb 9, 2013 01:47 PM
jk121
May 14, 2007 01:49 PM
js_specials
Aug 18, 2006 10:31 AM
