Rear end interchangeability
My googling didnt give me accurate answer.
Is the rear under 76 Cutlass ( 8.5" 10-bolt) interchangeable with a rear under 77-84 C-body? Attaching points-wise etc. Width? Question arose since the frames are virtually same from my understanding. And i may have something going.
Thanks.
Thanks.
Yes, BUT wheel bolt pattern and lower control arm bolts could be different hurdles.
5x5 to 5 on 4.75
diameter bolts on the control arms. metric full size a body etc.
all mounting point should be the same sedans
!!!!!! EXCEPT WAGON !!!!!!! they are wider than the sedan rears.
5x5 to 5 on 4.75
10 bolt 8.5 corporate rears are all the same from 1971 - 1987
28 spline
bolt in axle rears can use both c-clip and bolt in axle carriers posi or open
c-clip rears must use the c-clip carrier posi or open
so, yes.
28 spline
so, yes.
Also interchangeable for the 73-77 A body cars is 77-96 B Body 8.5. Easy way to tell in most cases is the 5x5 bolt pattern. Most light duty cars got the 7.5" rear with a 4.75x5 bolt pattern.
Mounting points are all the same (except wagon springs) however, the bushings for the lower control arms are larger so you will have to use a spacer to pick up the gap if you're using the A-Body control arms.
Bolt pattern can be resolved using a drill guide from Hells Gate Hot Rods OR purchasing new axles (SVL-2022589-3).
