Differential cover
Old Jun 26, 2012 | 02:00 PM
bobfo1's Avatar
Differential cover
If I'm installing a differential cover and using a gasket, do I need to use some kind of sealer with the gasket, or do I simply install the gasket as is?
Old Jun 26, 2012 | 02:37 PM
jensenracing77's Avatar
i don't use any on mine and never had a problem. the factory didn't use any either. just make sure both surfaces are clean.
Old Jun 26, 2012 | 02:53 PM
stlbluesbrother's Avatar
That is my experience, too. Gasket only - torque bolts to spec.
Old Jun 28, 2012 | 09:25 PM
monzaz's Avatar
Gasket sealer etc
With the aftermarket gaskets, USE sealer. Better safe that sorry.
Gaskets are much thinner and not made from the same material as older stock.
Good luck. Jim
J D
Old Jul 28, 2012 | 11:06 PM
DeltaDevil88's Avatar
Seems like I always hear its about 50/50 people use gasket with sealer and other half use only gasket wish we could get a definitive answer on this question.
Old Jul 28, 2012 | 11:53 PM
bdub217's Avatar
Kickin' It Oldschool
Put it this way, using sealer on the gasket won't hurt anything.
Old Jul 29, 2012 | 03:27 PM
monzaz's Avatar
cover gasket
IF you do not plan on going in all the time (race application) Then seal both sides and BE DONE.... guarantee not to leak.
Jim
JD
Old Jul 31, 2012 | 06:35 AM
Lady72nRob71's Avatar
I would use sealer, since the new gaskets are thin cardboard. I wish there was a rubber version made for these.
Also check the flatness around the bolt holes before reinstalling.
costpenn
Sep 30, 2014 06:33 AM
69ishHoliday
Dec 1, 2013 02:05 PM
Pacecar
Aug 8, 2012 04:40 AM
VikingBlue
Jun 4, 2010 03:07 AM
65Delta88
Drivetrain/Differentials
Sep 24, 2008 06:46 PM
