Alternator Question
Grounds....grounds.... grounds. Check, clean & seal with clear ignition sealer...all of them. The Negative & Positive cables need to be serviceable and exhibit low resistance. Check the connections at both ends. Any car guy should buy a decent Volt Ohm meter if you dont already have one? Also have your battery load tested. You may have a battery that has bad cells. Surface charge is 12-13vdc but as soon as its loaded it falls on its azz. If your alternator is dealing with bad grounds and a bad battery it will give some of these symptoms. A simple restive battery load tester isnt expensive. It will show charging voltage too.
I drove my Cutlass to work this morning. All was somewhat ok till I was about 5 minutes to work. The charge light came back on and wouldn't go back out like before. I'm getting frustrated with the car. I have checked my wires and they seem ok and the belts are good. I don't know what else to do. My second replacement alternator should be in today and will replace it when I get home. If that don't fix it then I am totally at a loss.
Send some pictures if you can. #1 Belt layout, #2 Back of Alternator, #3 Battery area. Maybe a picture will show us what might be missing?
Check to see if you have a braided ground strap, running from the engine block to the firewall. Find and clean connections. A missing engine block ground will cause light flickering as the engine shakes.
I am not familiar with the wiring of an 87 olds, however, a loose ground in the instrument panel, could cause a false alternator light.
If possible,try to temporarily mount a digital volt meter to your Dash or console (clear packingtape). Connect the DVM leads to a good Ground screw and the positive to an easy to find wire, such as the Radio wire or fuse panel. This will allow you to see the voltage while you are driving.
Voltage at speed:
All-off (turn off headlights, Radio, AC, etc)
Running at Idle,(All-off), over 13.0 (preferably 13.8 range)
At speed 30+(All-off) over 13.5, should be 13.8 to 4.1 depending on accuracy of meter and connection location.
Did you ever get your battery officially tested? What were the results?
Voltage at speed:
Now, all of this is moot if the O.P. really is getting less than 13.8V directly out of the alternator.
When a generator is tapped, it electrically brakes the motor. That it started squealing when the voltage jumped into the acceptable range means 2 things. One, the belt wasn't tightened correctly ... and 2, that when it wasn't squealing, there was no demand for power from it. To me, that points right to the voltage regulator.
442mark
Sep 30, 2017 01:06 PM
