Rear end question
Old Jul 19, 2008 | 05:11 PM
1964Jet*88's Avatar
Rear end question
Yes I tried to search but couldn't find anything...
I recently picked up an '86 Cutlass with a freshly rebuilt 305. if I take off easy it's fine, if I try to get on it to hard my rear end grinds.
I'll be heading to the local Pull-a-Part next weekend to grab the diff. and a door.
What rearends will bolt up? I'd like a better ratio if possible.
Any G-body should work right? '78-'87? Anything else?
Also what year doors match my '86?
Old Jul 20, 2008 | 07:09 AM
The problem is that your Olds is rejecting the Chebby motor, like a heart transplant gone bad...
Seriously, any 78-88 G-body axle is a bolt-in. No other axles fit without work. All but the 84 H/O and 85-87 442 and Buick GN will be the same weak-kneed 7.5" axle that was originally born under the Vega. If you do happen to find the 8.5" from the 442 or GN, you'd better also start buying lottery tickets because you have incredible luck.
Old Jul 20, 2008 | 08:01 AM
1964Jet*88's Avatar
That's about what I figured.
What ratio's were available?
How about the doors? I know the early models won't fit but what about '84,'85, and '87?
Old Jul 20, 2008 | 09:05 AM
BILL DEMMER's Avatar
Just the facts...
'81-'88 are g-bodies, '78-'80 are a-bodies.
doors from '81-'88 buick regal and olds cutlass are what you're looking for.
a 7.625 rear will hold up behind a plain 305, for a very long time.
bill
350TurBRO
Sep 12, 2014 11:52 AM
jpc647
Drivetrain/Differentials
Jul 7, 2014 10:39 PM
72greensupreme
Mar 25, 2009 06:13 AM
1964Jet*88
Jul 21, 2008 05:26 PM
Good_Music_n_Cars
Oct 16, 2007 07:35 PM
